Can MBS-Navision Standards be installed in a multi location environment? If yes, then how will the connectivity be done?
Multi location should be no problem, but is depending on the connection between the locations. Make a search on the forum on : - citrix - terminalserver - lansteiner - gopro , go pro this theme is more often discussed as you think !
Citrix works fine.
Depends on the budget. Citrix is a better solutions. but if there is a budget constrain, Terminal services is fine too.
By the way, lansteiner is a company’s name of an NSC. Go Pro is a POS system developed by Lansteiner on Navision platform used by company like Ikea…
