we have errormessages in eventlog on our citrix server, which is windows 2003 server, sp1, citrix mf ps 4.0 and axapta client 3.0 SP4 in 3-tier mode: faulting application ax32.exe, version 3.0.1951.4060, stamp 41dbb317, faulting module unknown, version 0.0.0.0, stamp 00000000, debug? 0, fault address 0x030a3a5c. has anyone an idea what could be the reason for this error or has someone even a solution for that ? Thanks a lot Greetings FIVE Informatik AG Alexander Schild MCSE, CCA
Hi, We have been using Citrix/Axapta combination for more than 2 years now without any problems. In order for us to help could you let us know the following please - - Are you able to run Axapta from Citrix server at all? - Also when and what instance this error message is generated? Regards, Harish Mohanbabu
Hello, Yes we are able to run axapta. User’s do not report any explicit error or crash of axapta. The only thing I see are these entries in the log.
