MB7-840
Hi to all,
i have also some other questions
  1. suppose while running the codeunit u got the run time error when u review the code u found out the string is overflow by which function u can resolve the problem(select 2 options)
A. SELECTSTR
B. MAXSTRLEN
C. STRPOS
D. COPYSTR
2.if u created ane array with 10 index having variable name SalesPrice now u want to delete the 4th and 7th index’s data which syntax u will use?
A. SalesPrice[4] := 0;
SalesPrice[7] := 0;
B. SalesPrice[4,7] := 0;
C. CLEAR(SalesPrice[4,7] = 0);
didnt remember the last option
Thanks.
  1. B&D
  2. A
Jay I think you need to read technical Manual of Navision as well as try some questions in Navision by writing given code in question You will surely get all answers …
All the Best[:)]
Thank u for the advice.
I have thoroughly read the book called Programming Microsoft Dynamics NAV and also done the practice in NAV Classic.But some of the topics haven’t covered in this book special codeunits,Menusuites.so can u suggest me some materials that covered this topics.As u mentioned technical manual of Navision from where i can get this material.
Thanks a lot Mohana
