Maximize Button is Disabled in AX Form Window
How to enable that and that form containes 16 fields.
Thanks in Advance
Check in form design properties - what settings do you have on MaximizeBox and WindowType properties…?
What about those 16 fields…? Didn’t get that…
go to you form then go to the properties of the “Design”. change the WindowResize property to Dynamic. Hope this works =]
Change the properties of the group
Width - Column width
Height - Column height → which enables the maximize and resize options…
Hai as said above width and height properties would solve the maximize problem .
But i would suggest to display only minmal field in the front tabpage nd remaining in a diifrnt tabpage
