MatrixBox
Hi, I have a matrixbox in a subform and I wanted to know if it’s possible to dynamically display certain column of the matrix (ie not display column with empty value) Big Big Thanks in advance CHH
Yes it can be done…no it is not easy. Basically you need to put a function in the sub form that will set a filter on the matrix column. To do this you need a field in the source table that can be filtered. Then you need to pass a value to the sub form. Then the main form needs to update the subform when you change records. It takes a lot of silly coding, but you will get there in the end. THe end result is worth it.
THanks to David I Know it’s possible. But someone could provide me with an example because I am quite a newbie with navision (3 month not full time)
