I have an query in the routes. For a operation i have defined the run time as “110” hrs and in the general tab against the Work center, I have mapped the Work center group and given the Qty of Work centers has “4” and load is 100.
If we manually raise the Production Order for the FG Item, there are 4 Jobs created against the Operation with different Work Centers with run time as “27.5” hrs against the 4 different work centers which is correct.
Is the same thing applicable if we run the Master Planning? because for the same FG Item, AX schedules the JOB against the 4 different Work centers associated with the Work center groups, but the run time is not been splited into 4 Work centers with the run time as “27.5” where as each work centers has been allocated with 110 hrs.
Is there any parameter to do that, or AX will not consider Qty of work centers during Master Planning?
Awaiting for your feedback.
Satish EC
