Master Planning for Specific Item Groups
Hi there,
I setup a min/max coverage group and assigned it to all items within a specific item group. When I run master scheduling, the planned purchase orders for these items are created as expected. However there are planned orders created for items that I did not apply item coverage settings to. These items have negative stock and belong to a different item group.
Is there a way for master scheduling to only create planned orders for the item group I have setup with item coverage? I want to avoid generating orders for all other item groups, since they aren’t required and are using a large volume of numbers in the number sequence.
Thanks in advance for any help you can provide!
Hey Dunaric,
The way you would do that is by assigning those items to a coverage group using the “Manual” coverage code. “Manual” means AX won’t plan for them.
-Jake
Hey Jake,
That’s great, thank you very much for your help! :slight_smile:
Dunaric
