I apologize if this is the wrong forum for my question but I can’t seem to find help anywhere else.
Our Company just purchased MS Dynamics NAV 2009 R2. We also purchased the Classic Nav 2009 R2.
I am a beginner as I have less then 10 hours using the Classic Nam software. I am using a Dataport to load information into the items table. The inout file is a text file. I verified all fields are in the correct order and of the correct type and values. When I go to run the import I get a Master File Setup Primary “” does not exist error.
If it’s your first time importing - It might be a good Idea to put 1 test item in manually.
Then after your import you can view the item table to compare all the fields from the manually entered item against the imported items. Then you’ll know for sure your valudations n such are correct and you didn’t miss anything.
Is you dataport filling the Item Unit Of Measure table at the same time?
