Master details view wrong information display
Help! I’m new at AX2012.
Target module: Human resources>Common>Workers>Workers
When you double click a record, a detailed view/worker summary form will pop-up right? All the information is correct.
But when I use the advanced filter, select show records active as of and input a date.
Then, select a record.
A wrong information is displayed or a blank. What do you think might be causing this problem?
on what method should I focus? I’m wondering how records and displays are transferred to the details form.
Can someone enlighten me? I’m trying to debug it but its really time-consuming stepping in each line of code and reading if the values are correct.
Thanks!
