Mass Updating the "use cost price by variant" through SQL statment
I have updated the filed “use cost price by variant” for all items through a SQL statment, but it dosnt activate the relevant functions.
When I update this field manually, it gives firstly a confirmation message , then we press “ok” then the relevan t function is activated.
Any one know what should I do after running the update SQL statment to activate the function of that field?
Ehab Radwan
If bypass AX application logic by direct SQL updates, you shouldn’t be surprised if you end up with inconsistent database.
Forger about SQL, return to AX and look at what code is executed if you do your manual steps.
(Question moved to the Developer forum.)
