While invoicing this error is throughing “cannot create a record in markuptrans , record already exists”
while invoicing through pending vendor invoice
i.e invoicing one by one item through pending Invoice
please help its urgent
You’re in a developer forum, so I suppose you’re able to debug code to see which markup trans is causing the issue. Since the problem is in your system, nobody else can do the analysis.
