Marking transaction from code in Ax 2012
I need help with marking transaction please. I found code but calling TmpInventTransMark::updateTmpMark(… show error: Transaction has been changed. Could somene help me with it please?
static void testXppMarking(Args _args)
    InventTrans issueInventTrans;
    TmpInventTransMark tmpInventTransMask;
    Map mapMarkNow;
    container con;
    real qty;
    Map mapTmp;
    MapEnumerator mapEnumerator;
    InventTransOriginId issueInventTransOriginId =
        InventTransOrigin::findByInventTransId('Issue lot ID').RecId;
    InventTransOriginId receiptInventTransOriginId =
        InventTransOrigin::findByInventTransId('Receipt lot ID').RecId;
    InventQty qtyToMark = 11;
    ttsBegin;
    issueInventTrans = InventTrans::findByInventTransOrigin(
        issueInventTransOriginId);
    [con, qty] = TmpInventTransMark::packTmpMark(
        InventTransOrigin::find(issueInventTransOriginId),
        issueInventTrans.inventDim(),
        issueInventTrans.Qty);
    mapTmp = Map::create(con);
    mapEnumerator = mapTmp.getEnumerator();
    while (mapEnumerator.moveNext())
        tmpInventTransMask = mapEnumerator.currentValue();
        if (tmpInventTransMask.InventTransOrigin == receiptInventTransOriginId)
            tmpInventTransMask.QtyMarkNow = qtyToMark;
            tmpInventTransMask.QtyRemain -= tmpInventTransMask.QtyMarkNow;
            mapMarkNow = new Map(Types::Int64, Types::Record);
            mapMarkNow.insert(tmpInventTransMask.RecId, tmpInventTransMask);
                issueInventTransOriginId,
                -qtyToMark,
                mapMarkNow.pack());
            break;
    ttsCommit;
