MARKED ONLY Records
Hello All,
I have a situation and would like to have you inputs in it.
1 of my customer has a requirement to display all the Inventory of items, he will select few lines from the list by marking it (Ctr+F1).
I need to write a code to bring all those marked lines on Sales Order. So the customer can work further.
I am displaying directly ILE form with applying required filters while opening the form this part is working fine.
I have added a button on which I need to write a code which will populate sales line with the Markedonly records.
Any inputs and suggestions are welcome.
Thanks in advance
MAS
Got the solution for the said issue.
After MARKEDONLY(TRUE);
IF Rec.FIND(’-’) THEN
BEGIN
REPEAT
CAL Statements
UNTIL
END
Good to Hear That!!!
