hi every one
i am using mark function for Some Conditions apply to Records. that Records only Marked But My Question is How many Records has been marked how to know ?
i kept message but it shows only (yes,No).Please Help me
Thanks & Advance
Siva
hi every one
Thanks & Advance
Siva
You can do a Record.MARKEDONLY to set your filter to only marked records. Record.COUNT will give you the number of records in the filter.
Did you try with Record.COUNT after Record.Marked(TRUE);?
Thank You For kind Reply i reach my Requriment
Can you verify the solution which solved your problem?
I never saw you verifying the solution… [;)]
