Mark a record on checkbox click
Hi guys,
I have a form based on the grid my requirement is that i have a check box on this grid when i click this check box or when i select the check box the record in this grid should be marked.
I want to process these marked records. But i don’t know how to mark them through code.
I am not getting you.
Arun Garg
I created a new overview form with the GRID. This grid contains the check box when the user selected the check box the record should be marked.
The user can select multiple records using this check box on the grid.
Look into the planned orders form, the same thing has been implemented there…you can use map, mapIterator classes to achieve this…
