Does anyone know of a tutorial to show item usage in NAV for manufacturing I am needing to generate a report that shows how much of each item we use on a monthly basis. thanks
Your usage is defined in the Item Ledger Entries. If you’re talking manufacturing, look for the Consumption entries.
Check in the Mfg module for standard reports.
Is the ‘Quantity’ in the Item Ledger entries table is the ‘Quantity used’
