While installing AX2012 (after database splitting in inplace upgradation from FP to R3 ) i am getting following error … please help me out
Error occured While installing AOS
and log file information is
Is it fresh installation or Updates with Existing AX Installation ?
Hi saadullah ,
it is fresh ax installation(Only aos component installation) with existing upgraded databses
First restart the complete server, I hope you have Existing DB with CU9 version. , Also make sure u have CU9 updates install it with slipstream installation method
here i am upgrading Ax2012 CU5 to Ax 2012 R3 CU9, i had split the db with CU9 setp from there i want to install AOS…
in ax 2012 r3 installation folder have you included the Cu 9 updates ?
yes, updates folder has included…
the cause of error is stored procedure
