I would like to install the management reporter for Dynamics AX2009 for testing purposes on my local machine. Unfortunately, I have only a VPC Application of Dynamics AX2009 and do not know how to install the management reporter on this virtual machine. I am using the Microsoft Virtual PC 2007. Any hint would be appreciated.
I downloaded the software on my local computer. As I am not a ‘technical guy’ I do not know how to install that software on Dynamics AX, which runs on the VPC. There seems to be no connection between the VPC and my local hard disk where I saved the download. What can I do?
There are 2 ways.First one is just drag that software to vpc desktop and drop it.and then install that and go through the above process as i have given in the earlier.Second one is goto the VPC settings Shared folders create share folder and then u past that s\w in to that folder.and open the vpc my computer u will get shared drive in that u get ur software then install that ok na .i hope it may help ful. good luck
