Hi, I tried to install management reporter at the end it’s not installed. It’s showing error and in event log it shows like this: The description for Event ID 108 from source Dynamics .NET Business Connector 6.0 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event: 6.0: Dynamics .NET Business Connector The specified resource type cannot be found in the image file. Thanks, Sathish
This is common error which shows in event viewer.
Please go through the below link and try again once.
http://talasilarahuldaxing.blogspot.com/2014/10/how-to-install-management-reporter-in.html
Rahul
