I’ve installed MR client in my machine and have given ‘administrator’ rights in MR for my login credientials.
When i access ’ Report Viewer’ i’m can view all the reports which have been generated.But when i generate a report in the ‘Report Designer’,the generation of report is interrupted with an error.
Please help.
-Rajee
It seems that there is some connectivity issue in the default company.
I will suggest you to check the setting again and verify that the connection is successful.
For the error messages, they are reappearing on the report run even after the problem is rectified. I haven’t found how to update the screen.
Pranav…
If there seems to be a connectivity issue,then how can i view the reports in the ‘Report viewer’ ?
