Hello All,
I got some issues with Management Reporter 2012 in combination with the AX2009 I receive the following error when trying to add a new row ,column Definition and even when using wizard:
The operation could not be completed due to a problem in the data provider framework Action: schemas.microsoft.com/…/SubmitRequestServiceFaultFault Fault code: Sender IsSenderFault: True IsReceiverFault: False Reason: The operation could not be completed due to a problem in the data provider framework. stackTrace Server stack trace: at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at Microsoft.Dynamics.Performance.Reporting.DataProvider.Service.IDirectLinkService.SubmitRequest(ServiceDataWrapper1 request, DataServiceConnection connection) at Microsoft.Dynamics.Performance.Reporting.DataProvider.Client.DirectLinkClient.<>c__DisplayClass23.b__21() at Microsoft.Dynamics.Performance.Reporting.Common.Service.ClientBase.<>c__DisplayClass81.b__5() at Microsoft.Dynamics.Performance.Reporting.Common.Service.ClientBase.<>c__DisplayClass81.b__3(Func1 T) at Microsoft.Dynamics.Performance.Reporting.Common.Service.ClientBase.<>c__DisplayClass8`1.b__4()
