Management Reporter 2012 Issue
I am using MR 2012 with CU14 on SQL Server 2014. MR installation was done properly, however when ever I click on the column definition it gives an error message The operation could not be completed due to a problem in the data provider framework. Component: Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkService.
While I did some research on this issue I found that the, this could be because of duplicate dimension values, which were corrected, next it could be for currency which has also been setup. Even refreshed the data mart. But I am still facing this issue.
Any help in this regard will be highly appreciated.
