Making a String Variable's Text as Bold .....?
In a display method i have a string variable like
Display str notes()
Str notes = “dynamics ax”;
Return notes;
now i want to print this as
dynamics ax
Thanks In Advance
Hi Bobby,
In design, you can find property called “change case”. You can set it as upper case to display in upper case.
S.Kuppusamy
Hi ,
If you would like to display your value in bold,You can set the bold property on the string control to bold.
rgds,
narayan
