Is it possible with Axapta 3.0 to make one purch order from different projects with the same product needs?? I hope somebody can help me! Greetings Jos Jonker
Not directly. You can only create a project PO from the project level against which the costs will eventually be posted. You may be able to use the item requirement feature and then master planning to get a consolidated order, but I think these goods will be delivered to inventory and not project - but it may be what you need.
