when i was copying the field values from one table to another by using main method in table thats not working…
but same code wrote in under AOT-> jobs node by creating a new job … its working … what is the reason behind that
Something is wrong in your code. But unless you show us the code, it’s impossible to say what’s the problem.
static void Job16(Args _args)
Custtable custtable;
DupCust dupCust;
RecordInsertList recordInsertList;
recordInsertList = new recordInsertList(tablenum(dupCust));
while select linedisc,Custgroup,invoiceAccount,Telefax,Phone,Address,Name,AccountNum from Custtable where custtable.AccountNum > ‘0’
dupCust.AccountNum = custtable.AccountNum;
dupCust.Address = custtable.Address;
dupCust.CustGroup = custtable.CustGroup;
dupCust.InvoiceAccount= custtable.InvoiceAccount;
dupCust.LineDisc = custtable.LineDisc;
dupCust.Name = custtable.Name;
dupCust.Phone = custtable.Phone;
dupCust.TeleFax =custtable.TeleFax;
dupCust.insert();
} this one is working but
same code write in under STATIC VOID MAIN(Args _args) method its not working …
There is a fundamental issue in your above code.
You are not using ‘RecordInsertList’ class properly. See here for an example - http://msdn.microsoft.com/en-us/library/recordinsertlist.aspx
thank u harish …
but in my project i don’t want to need copy the all values from one table to another only some of the fields … i tried by using just insert method in the traditional way …
but its working on JOBS not working in the main method
How you are running the code in main method? Try debugging the code to find why it doesn’t works .
You should try the set based operation insert_recordset
