Machines
Hi Guru’s This is a manufacturing company . So it needs capital items( Machines) to produce finished item.When it comes to Machines , they are purchasing in two ways.1. Directly from vendor2. Purchase subparts and make the machine at their plant with workers.Client will issue daily some parts to workers to make machine like this daily they use to issue parts.What the client is asking how to handle the second scenario. What is the best solution to track the items, to issue the materials, after complete that task how to know the cost of that Machine.Like this they will make lot of machines which each machine worth is 10,00000 INR.Is there any default solution is available ?What is the best solution Could any expert throw some help ………………………
Sorry are you simply talking about using the manufacturing elemnents of NAV to build a product rather than purchasing it? You cannot capitalise this as a fixed asset, but you could manually enter this. Have you seen the manufacturing elements?
