What is the licensing methodology in LS Retail for the following secnario
We have one HO and two Stores at different locations. we require two NAV users at HO and 2 LS POS Users at each location.Can anybody advise us the licensing requirement for LS Reatil/NAV
You have to buy seperate POS licences for each POS and for each Store you must have Store server Licence. For HO you can have 2 user Licences if both are using concurrently.
We also provide our services in Middle East & Africa region as LS Retail platinum partner. We can help you procure these licenses as well as provide you implementation and consultative services on the solution. Do let me know at sales@dynamicverticals.com if you have any of these requirements.
His Post Seems that he will have 2 POS in each store and 2 stores are there. So 4 POS will come in to picture. Then how can he proceed with 2 POS Licence?
we need to activate the Lot Wise item tracking in LS Retail POS. We have created the barcode mask as follows
87IIIIITTTTTM
Item No. 38002
Barcode: 8738002000000
We have received the items with a lot no. 10003
when I am using this barcode 8738002100031, system is giving the warning “Invalid Lot No.”, Do you want to use? If we cancel the warning message, system showing another message as Lot No. Item Tracking not supported without “Inventory Lookup”
