Hi all
Myself Nitin Patil
I m facing problem in LS retail Data Director,When I m trying to take test connection with data director I get below error.
" 12296 : Error Connecting data base"
I check connection string and its working fine.
Below are my environments for DD
I m using 6.00 sql server for connecting the data director.
I m able to acces database from my outlet as well as HO.
I m using one server for two different outlet.
Using two different ports for respective outlet.
Second outlet is running successfully.
Same condition in Host and services file which I use second outlet.
Kindly help me out to remove this error
Regards
Nitin Patil
