Please help! Has anybody C\AL samples for Integration with LOTUS Notes ?. I try to get field value “Company_Index” from some Lotus database The similar code in Excel works fine. I try code below, but after line doc.GETITEMVALUE(‘Company_Index’) i get the error. ----------------------------------------------- CREATE(session,TRUE); server:= ’ '; base:= ‘Contr.nsf’; db:= session.GETDATABASE(server, base) ; dbIsOpen:=db.ISOPEN; IF NOT(dbIsOpen) THEN BEGIN ERROR(‘No database’) END; collection := db.SEARCH(‘Form = “Company”’,LLdate,0) ; doc:= collection.GETFIRSTDOCUMENT(); doc:= collection.GETNEXTDOCUMENT(doc); n+=1; REPEAT LotusTable.INIT; //here i get error: ‘‘this automation variable has not been instantated’’ varCOMPANY_INDEX:= doc.GETITEMVALUE(‘Company_Index’); IF varCOMPANY_INDEX.ISTEXT OR varCOMPANY_INDEX.ISINTEGER OR varCOMPANY_INDEX.ISDECIMAL THEN LotusTable.No:=varCOMPANY_INDEX; LotusTable.INSERT; doc:= collection.GETNEXTDOCUMENT(doc); n+=1; UNTIL (n>200) ----------------------------------------------------- VAR’S: session:‘Lotus Notes Automation Classes’.NOTESSESSION"; db NOTESDATABASE"; dbIsOpen: Boolean; server : Text[255]; base : Text[255]; collection : Automation :‘Lotus Notes Automation Classes’.NOTESDOCUMENTCOLLECTION"; doc : Automation :‘Lotus Notes Automation Classes’.NOTESDOCUMENT"; LotusTable : Record 70000; n : Integer; LLdate : Automation :‘Lotus Notes Automation Classes’.NOTESDATETIME"; varCOMPANY_INDEX : Variant; varCOMPANY_NAME : Variant;
