My Ax instance has 4 companies.
I am able to post the Packing slip of PO in 3 companies but when could not post in 4th one.
Error is " Lot ID is not specified".
Am I missing any set up in that company?
Thank you.
Anitha
Thank you.
Anitha
Lot id is the transaction Id(unique) which will be generated by the system. Not sure how the transaction are being entered into the system?
Can you run the number sequence wizard and then it will fulfill the number sequence reference, unless you have somehow migrated data into this company?
