Loop Through Fields with same name
Hi guys,
Do any of you know how to loop through fields in a table, the example being: Day 1, Day 2, Day 3,…,Day 31 in Nav 2009 R2? I have code:
If “Day 1” Then
If “Day 2” Then
And so on
Hi'
This code will loop through all records and you can put your test statement inside it.
Is this what you are looking for?
IF SomeRec.FIND('-') THEN
  REPEAT
    IF SomeRec.Field = "Day 1" THEN
        BEGIN
           (put code here)
         END;
  UNTIL SomeRec.NEXT = 0;
Not really what I am looking for. Maybe I was not clear. The code you supplied requires me to write manually the same thing for all 31 days and this is exactly the thing I want to avoid. I am looking for an equivalent of a FOR loop (Day[i]), which ,of course does not work in navision.
You can look at Date table…
What do you mean by that? What will I see there?
I havent tested this, but it’s something along these lines… It loops through all records 32 times though…
While i < 32 DO
BEGIN
IF SomeRec.FIND(’-’) THEN
REPEAT
IF SomeRec.Field = 'Day ’ + FORMAT(i) THEN
BEGIN
(put code here)
END;
END;
If you need the current number of days within a month you could use
NoOfDaysInMonth := DATE2DMY(CALCDATE(‘CM’,DMY2DATE(01,MonthNumber,YearNumber)),1);
And replace 32 with that!
I will test this tomorrow and let you know if it works and I will post here the solution. Thanks for the guidance.
Hi Georgi,
Are you saying that you have a table with fields named “Day 1”, “Day 2” … “Day 31”, and you’re interested in inspecting the values of these fields without having to refer to them explicitly in code? If that’s the case, take a look at the documentation for data types RecRef and FieldRef.
