Hello All,
I need to show combination of 2 fields as a singled field for a lookup form.
However on selection of an entry from lookup form, primary key should be used ( which is part of combined user fields)
Please suggest.
Neetu
Hello All,
Please suggest.
Neetu
hi,
if you want to combine to field and show it as a single field in lookup form then you need to have one more column in your table that will show the combination of the 2 field .
