I’ve a dialog with some selection criteria and three fields of them are the 3 dimensions. The lookup function, if called, returns an error.
Trying to get a solution, I’ve looked in the standard classes to see if someone has declared a dimension field in a dialog. There is the LedgerTransOpening that does exactly the same as my class, but… when I do a lookup to a dimension from this class I get the same error. It seems that DimensionsLookup cannot be called from a class.
Someone can confirm to me if the same problem is present in his installation of AX2009? If it is so, it’s a standard bug, elsewhere can be a problem of my installation.
I suppose that the Dimensionslookup is written in a manner that can be called only from a form and not a class.
I actually had a dialog the other day where I wanted to add a Dimension field with the posibility to do a lookup. I didn’t go by using a lookup, but Instead went by using an extended datatype to make AX automaticly create a normal lookup.
I created a ExtendedDataType which I called DimensionOne.
This one Consists of relations to DimensionOne == Dimension.num. And 0 == Dinemsions.DimensionCode, where 0 is the dimension you want to use
After that I declared it in my dialog. Se sample below
public Object dialog() { DialogRunbase dialog = super(); DimensionOne dimensionOne;
DialogField ConceptStr; ;
conceptStr = dialog.addFieldValue(typeid(DimensionOne),dimensionOne,“Label here”,“Some help text”); return dialog; }
This would create a field with a “pillow” in your dialog, where you can push the pillow and have a lookup.
Was this what you where after or did I missunderstand the question? (got this tip from some other place on the internet, credits not all mine)
