LOOKUP FILTERS
Dear Pioneers,
I have to show PRODUCTION ORDERS in LOOKUP, In TRANSFER ORDER Form, In PRODUCTION ID, and it should show only the ESTIMATED & REPORT AS FINISHED production ids only in AX2009.
I wrote the code as below :
public void lookup(FormControl _formControl, str _filterStr)
// super(_formControl, _filterStr);
Query query = new Query();
QueryBuildDataSource queryDataSourceCode;
QueryBuildRange queryBuildRange,queryBuildRange1,queryBuildRange2;
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(ProdTable), _formControl);
sysTableLookup.addLookupField(fieldNum(ProdTable, ProdId));
queryDataSourceCode = query.addDataSource(tableNum(ProdTable));
queryBuildRange = queryDataSourceCode.addRange(fieldNum(ProdTable, ProdStatus));
queryBuildRange.value(enum2str(ProdStatus::StartedUp));
queryDataSourceCode.addSortField(fieldnum(ProdTable,ProdId),sortOrder::Ascending);
queryBuildRange2 = queryDataSourceCode.addRange(fieldNum(ProdTable, ProdStatus));
queryBuildRange2.value(enum2str(ProdStatus::ReportedFinished));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
Please suggest me, that IS IT NECESSARY TO WRITE A SEPARATE queryBuildRange2.value FOR REPORTASFINISHED ALSO ??
Need your suggestions Pioneers…
You defined 2 ranges on the same field, you can try to define one range like follows:
QueryBuildRange.value(strfmt("%1,%2",enum2str(ProdStatus::ReportedFinished),enum2str(ProdStatus::StartedUp)));
you can also set the sorting before the range definition
Hope it helps, please verify the solution if it solves your problem.
regards,
Thomas
Thanks A Lot
