Hello Pioneers,
I need to show the production Id in lookup in InventTransTable form, whose ProdStatus is : “CostEstimated”.
Please Guide me
Hello Pioneers,
Please Guide me
This might help you.
public void lookup(FormControl _formControl, str _filterStr)
Query query = new Query();
QueryBuildDataSource queryDataSourceCode;
QueryBuildRange queryBuildRange;
SysTableLookup sysTableLookup;
sysTableLookup=SysTableLookup::newParameters(tableNum(prodtable),_formControl);
sysTableLookup.addLookupField(fieldNum(prodtable, prodid));
queryDataSourceCode = query.addDataSource(tableNum(prodtable));
queryBuildRange = queryDataSourceCode.addRange(fieldNum(prodtable, prodstatus));
queryBuildRange.value(enum2str(prodstatus::costestimated));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
writ this in the inventtrans datasource prod id field lookup() method in inventtrans form…
Dear Chaitanya sir,
I am getting an error message "an overloaded function has an incorrect number of parameters "
where you are writing this code…
and which line you are facing the error in the code…
Problem Resolved Sir…Thanks A Ton !!!
