Lookup by code
Hi all, There is a problem a cannot solve, let me explain by an example: When you have a standard lookup, lets say an article in a purchase line, Navision remembers at which record you were when you close the lookup. The next time you do the lookup the previous article will be active again. The problem is that when you do the lookup by coding you cannot remember the last active article unless you save it somewhere. There must be a simpler way… Thank in advance, Reijer.
Look at the SAVE* properties in the lookup form. “SaveValues” might come handy in your case. With best regards from Switzerland Marcus Fabian
Yahoo, it works. Thank you very much Marcus. It is a shame that you have 4 stars. 6 golden stars it should be.
I hear Marcus has the well deserved six stars on the shirts he wears while he works on Navision projects. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
