i have written code equivalent for lookup on a field, but when i write anything on the validate trigger of the field, it is not being executed. thanks in advance kumar
hi Kumar, the validation-trigger is not executed until the user presses Return, of moves to another field in your form. So to execute the validation-trigger, select a value with your lookup, and then press enter. Good luck, Bartel W. de Leeuw
Bartel - That is only half of the truth. If you do the code on a form, the OnValidate and OnAfterValidate will not be execuded unless, you tell it to. OnLookup(VAR Text : Text[260] : Boolean As You see, the OnLookup (on the form) has a parameter, and a returnvalue. Normally I see people do something in this direction:
OnLookup(VAR Text : Text[260];) : Boolean
Customer.SETRANGE(Blocked,FLASE);
if form.runmodal(0,Customer) = ACTION::Lookupok then
"Customer No." := Customer."No.";
this will not run the OnValidate on the form. This is how I normally do it:
if form.runmodal(0,Customer) = ACTION::Lookupok then begin
**Text** := Customer."No.";
exit(true);
end else
exit(false);
This WILL execute the OnValudate of the FORM. //Henrik Helgesen [size=1]-: KISS::Keep it Si Edited by - hhelgesen on 2001 Nov 16 21:52:56
Thanks Henrik its working fine now. kumar
