In Ax2012, I am facing the problem that i have created a field Form Type in the Table, and use the EDT FormType_IN for that field. Now i am able to look up the field if i see it from table browser. But the look up of that field is not showing on the form.
Please suggest me how to do it.
I also use the code for look up the field in the data source of that form, in the field look up of that datasource.
i code as below-
public void lookup(FormControl _formControl, str _filterStr)
//super(_formControl, _filterStr);
SysTableLookup sysTableLookup =
SysTableLookup::newParameters(tablenum(SalesTaxFormTypes_IN),_formControl,true);
Query query;
QueryBuildDataSource queryBuildDataSource;
sysTableLookup.addLookupfield(fieldnum(SalesTaxFormTypes_IN,FormType));
sysTableLookup.addLookupfield(fieldnum(SalesTaxFormTypes_IN,Description));
query = new Query();
queryBuildDataSource = query.addDataSource(tablenum(SalesTaxFormTypes_IN));
queryBuildDataSource.addSortField(fieldnum(SalesTaxFormTypes_IN,FormType));
//queryBuildDataSource.addRange(fieldnum(Dimensions,DimensionCode)).value(Dimension.valueStr());
sysTableLookup.parmQuery(query);
sysTableLookup.parmUseLookupValue(true);
sysTableLookup.performFormLookup();
Regards
Vijay Parashar
