Hello!
In the C/AL editor I can write a 132 charachter long code line. But I need to write 162 charachter. How could I do that? Is there any properties for that?
Hello!
You cannot make code lines longer, but you can simply continue the line of code on the next line.
I have to write this line into a txt, because I want it to import like a codeunit. But this line is too long. But if I write it in two line, the program write a syntax error.
F.WRITE(‘XMLDoc@1005 : Automation “{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{F6D90F11-9C73-11D3-B32E-00C04F990BB4}:‘Microsoft XML, v4.0’.DOMDocument”;’);
The syntax error is due to the single quotes you have in the string you want to write to the file around the ‘Microsoft XML,v4.0’. Try it with 2 single quotes instead.
In other words:
F.WRITE(‘XMLDoc@1005 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221}’ +
‘4.0:{F6D90F11-9C73-11D3-B32E-00C04F990BB4}:’‘Microsoft XML, v4.0’’.DOMDocument";’);
I didn’t type that into C/SIDE, but it should be correct.
