I’m developer in Ax 2009 and i have a question.I changed extended data types table and then ax is closed. Now i try to open ax and it give logon error “connection with the application object server could not be established”. How can fix this error, please help me.
Now the new question is why your AOS can’t start. Did you make any configuration changes before it started happening? Can you find more information in event log on the machine with AOS?
