Logon as another user
How do I get the login dialog box enabled so I can login as another user? I’m using 2-3 different users depending on the user rights so I can’t spend all day logging off and on in Windows just to be able to change the Axapta user.
/Lars
Are you referring to the Ax 4.0 version? If yes, you should right-click on Ax32 client icon / Run as… and specify The following user.
Regarding DAX 4.0, do you need special access within Active Directory to enable you to “Run As” another user? For example, I know you need to know the domain\account name combination…but do you need to know the AD password for this user as well?
