Logo on Dynamics Ax 2012 SSRS Report - Display method
Hi!
I am working on a report which uses a Query as datasource and I have tried without result to display a logo that comes from a display method in the first table for the Query.
Is this possible or should I extend the query with companyInfo and companyImages tables?
Hai Pedro
can u tell me the exact requirement
Pawan
Hi. First I want to test if this works:
On my query, the first datasource have a table which have this display method:
public display Bitmap companyLogo()
return FormLetter::companyLogo();
I can selecte the display method on the report but the logo is not printed. So I dont know if I can print a logo that comes from a display method.
Hai pedro
I have face the same prob with display method for add the logo in the report,for adding the logo it is not working,but you can add the logo by right click where you want the logo in report and select image from that you can browse your logo of company,jope you also know this .
if you got the result through display method let me know
Thanks and Regards,
Pawan
HI Dear friends,
IN AX 2012 display method 'll not work in query based report.
U should see the below links:
http://blogs.msdn.com/b/axsupport/archive/2012/12/06/dynamics-ax-2012-reporting-how-to-add-company-logo-into-query-based-report.aspx
http://alfasith.blogspot.in/2014/02/how-to-add-company-logo-into-query.html
https://community.dynamics.com/ax/b/axsupport/archive/2012/12/06/dynamics-ax-2012-reporting-how-to-add-company-logo-into-query-based-report.aspx
