I have a NF 2.60 database running on SQL server. But when ever i try to log on to the sql server with the NF 2.60 client on another computer then the server i get an error message ‘Tabel data 2000000001 does not exsist’. The table in question is the object table. When i log on from a client running on the same server as the database is using, everything is working fine. Any ideas ?
Problem solved. It was caused by different language versions running on server and client.
