Login Form
Hi I have a problem regarding the login form…when i have selected the database & open a company then system asks for userid & password but this form appears at the leftmost corner of my screen i m not able to drag it down at the center, so i have a problem to insert the related info…can any one tell me why is it so…what’s the form id. thanks ashish bhardwaj
There is no Form object for the Login window, it is coded in the executables. This can happen in any Windows program that uses an MDI Form. Use the keyboard: - ALT + SPACE; - Select Move from the menu; - Move the window with the arrow keys.
hi, Delete your ZUP. Don’t forgett that al your Settings are gone also. Greetings, Johan
Delete the .zup file.
Don’t delete the ZUP file!!! There’s no need to do it! Just follow the instructions I posted.
Do as Nelson tells you!!
Nelson is right: ALT+SPACE, M, ARROWS… in cases the MDI form (main window) is selectable ALT+SPACE opens control menu for taht MDI frame and ALT+MINUS opens control menu for active “child form”
Robi, I think you meant ALT instead of CTRL. As for the child forms, you are absolutely correct that the ALT+MINUS is the proper shortcut. Strange that the Login window is not treated as a “normal” child form…
Thanks to all of u…for ur suggestion… Nelson it’s work fine with that…There is no need to delete the .Zup file. thanks ashish bhardwaj
quote:
[B)] yes of course, thanks, I have corrected the post…
Hmm - I guess we should have created a poll for this :wink:
Do as Nelson Said: ***** (5 Votes (Including me)) Delete the .zup file: ** (2 Votes)
And so, I can add annother post to my count - helpfullyness = 0
Does that require me to start a political campaign where I stand up for the rights of users who do not want to see their zup files deleted and years of settings and preferences just washed down the drain with a senseless click of the almighty delete key? Ohh, it’s just too late and my brain is still on…
Hail! admiral Nelson!! [:D]
