I can’t get the RTC woking at one of our clients in a 3-tier setup. I followed all the steps in the walkthrough (creating SPN’s, configuring the delegation for the relevant users) but it looks like the kerberos authentication is not working.
When i look in the eventlog on the server running the Nav Service is see successfull loging using kerberos. The eventlog on the SQL machine shows a login attempt using NTLM.
Are you sure that your clients network supports Kerberos? I had the exact same problem with a client a month ago and I had to change NAV from using TCPS to TCP, because their network didn’t support it. This was with NAV 4.0 SP3. Maybe it’s the same?
