Logging off user sessions forcefully
Hi folks! A practical problem! When using navision 2.0 financials, the users do not log off from navision system properly.When the navision server should be shut down, it does not do so properly. is there a way to have a view of all the users currently and after a particular time, the user should be logged off forcefully. Is there a way this could be enforced in 3. 3.60. Please help!!! regards, ramya venkat
Hi! Search the forums for “automatic logout”, you’ll find some ideas. If you run a SQL-DB, also check the download section. Regards, Jörg
