When making a TLog backup, it is usually truncated by default - else you have to state NO_TRUNCATE (not recommended!!!)
So, once the space was released after truncation, the SQL Server will write into the TLog from the beginning, actually the SQL Server is “rolling” through the file. Here it is important, to have the TLog at an optimal size, means to have it not too big, but also to avoid frequent file expansions/log growths. Hence, the best size of the TLog depends on the transaction-volume and the frequency of TLog backups.
The TRUNCATE_ONLY option is only feasible to prepare a SHRINK of the file, as you did. This is only recommended for specific purposes, e.g. after re-indexing the whole database, but not for normal business. Once you have shrunken the file, it may be necessary to expand the TLog (automatic growth). Each growth will create a new virtual TLog - the more VTLogs you have, the worse gets your perfromance.
Firstly, it depends on the maximum loss of data you are willing to accept; secondly, on the transaction volume you process; thirdly, from the db size and available disk capacity.
To have a full benefit from the SQL backup & restore features the answer to #1 is basically “no loss at all”, means to be able to restore the db until the very last committed transaction. #2: In NAV you usually perfrom a lot of transactions, most of them could hardly be reproduced after disaster-recovery. #3: The more backups you want to create, the more disk capacity is needed, of course. A pretty good & sufficient backup strategy could be - ignoring your specific environment - to proceed like this:
One Full-Backup per day; in the evening after business hours
A differential backup e.g. every 2 hours during business hours
A TLog backup every 10 Minutes (max. data-loss = 10 Minutes)
A “lower” alternative could this:
A TLog backup every hour (max. data-loss = 1 hour)
As mentioned, this may not fit for your specific requirements, but I hope this points out the basic idea …
