Hello Working on Navision version4 Location card Form ----> Zones And Bins tab How can I fill in these fields Receipt Bin Code field Shipment Bin code Adjustment bin code I mean in which case ? they should be enabled ?
Hi When the bin is mandatory and you use directed putaway and pick.
done … thank you steven
That was the easy part, setting it up and processing with it is slightly more complicated [:D]
