location card
hi forum
in location card there is a field called “Use ADCS”…i want to know the use of this field…and wat are the effects when i checkmark this field
ADCS - this is added functionality for the warehouse and streamlines the process (or adds in more steps depending upon you point of view). It stands for Automatic Data Capture Systems, I believe used to be a separate module prior to 3.60 and is now incorporated. It makes sure that the additional requirements of moving stock and doing stock checks is all-encompassing.
