Localization error
I installed 2009 with india localization,Deployed application.I can see all customizations and tables.When I open item master form system is giving error below method. “fiscalInformation_TaxationOrigin” is not exist.The reason is fiscalInformation_TaxationOrigin is form control with auto declaration “No” in property level.I am getting this error in most of the forms.In configuration level also I checked,my new instance and old instance is showing same configuration check.
Only the difference is auto declaration is true in old instance and false in new instance.What is the root cause of this error.
public void enableTaxationOrigin_BR(boolean _show = true)
fiscalInformation_TaxationOrigin.enabled(_show);
Did any one come across this issue?
